Date/Time: Sun, 20 Sep 2026 22:57:12 +0000
[Programming Help] - Clion Run/Debug Config Template attached
View Count: 1259
| [2024-02-18 02:41:22] |
| PeteB - Posts: 17 |
Hi, I thought I would post this BAT script which builds a chart study LLDB enabled debug dll from Clion without the need to cycle the Sierra instance. It also shows interaction with the UDP Sierra interface in a simplified manner. YMMV The script shown here is attached to this post as well. -- Pete Billing @echo off
REM ===================================================================================== REM --------------------- Clion Run Configuration Template ------------------------------ REM ------------------------------------------------------------------------------------- REM Build a Sierra Chart ASCIL module with DEBUG (LLDB) libs in Clion. REM ------------------------------------------------------------------ REM Required customization: REM (1) Check the vcvarsall.bat folder location. REM (2) Set DIRNAME and FILENAME env vars in the Clion dialog. REM DIRNAME=C:\SierraChart\SierraChartInstance_2;FILENAME=myStudyName REM (3) Check the Sierra UDP IP addr and port (using 127.0.0.1, 22093) REM GLOBAL SETTINGS->SIERRA CHART SERVER SETTINGS REM ------------------------------------------------------------------- REM The UDP command msgs goto Sierra Chart to unload/reload the dll. Otherwise the link fails. REM The call to VCVARSALL was copied from the output of a Sierra build in file REM .../ACS_Source/VisualCCompile.Bat REM The working dir is set via pushd. The working dir must be set. REM ===================================================================================== pushd %DIRNAME% set "c= $client = New-Object System.Net.Sockets.UdpClient; " set "c=%c% $bytes = [System.Text.Encoding]::ASCII.GetBytes('RELEASE_DLL--%DIRNAME%\Data\%FILENAME%_64.dll'); " set "c=%c% $client.Send($bytes, $bytes.Length, '127.0.0.1', 22093); " set "c=%c% $client.Close();" powershell -Command "%c%" powershell -Command "Start-Sleep -Seconds 1" call "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build\vcvarsall.bat" amd64 cl /JMC /MP /analyze- /Zc:wchar_t /Z7 /Od /GS /W3 /RTC1 /Zc:inline ^ /D "_WINDOWS" /D "_USRDLL" /D "_WINDLL" /Gd /Gy /GR- /GF /fp:precise ^ /MTd /std:c++17 /LD /EHa /WX- /diagnostics:classic /nologo ^ /Fo:"%DIRNAME%\ACS_Source\%FILENAME%.obj" ^ "%DIRNAME%\ACS_Source\%FILENAME%.cpp" ^ /link Gdi32.lib User32.lib ^ /DLL /DYNAMICBASE /DEBUG /INCREMENTAL:NO /OPT:REF /MACHINE:X64 ^ /OUT:"%DIRNAME%\Data\%FILENAME%_64.dll" set "c= $client = New-Object System.Net.Sockets.UdpClient; " set "c=%c% $bytes = [System.Text.Encoding]::ASCII.GetBytes('ALLOW_LOAD_ALL_DLLS'); " set "c=%c% $client.Send($bytes, $bytes.Length, '127.0.0.1', 22093); " set "c=%c% $client.Close();" powershell -Command "%c%" popd Date Time Of Last Edit: 2024-02-18 19:00:17
| [2024-02-18 18:23:16] |
| gtaranti - Posts: 99 |
Thank you, I adapted it a bit for my use case, but it's certainly working perectly! |
| [2024-05-16 15:52:46] |
| User389369 - Posts: 6 |
+1, works beautifully. Thank you very much.
