Date/Time: Mon, 25 Nov 2024 16:24:05 +0000
Number bars
View Count: 297
[2024-02-17 14:49:07] |
User575399 - Posts: 322 |
Is it possible to show a only a certain delta number on the side of the number bars? For example: only show delta over 100 I tried every setting. Nothing works Date Time Of Last Edit: 2024-02-17 14:49:44
Screenshot (78).png / V - Attached On 2024-02-17 14:48:57 UTC - Size: 43.82 KB - 62 views |
[2024-02-17 22:10:41] |
Anyone?
[2024-02-18 04:11:04] |
Hello?
[2024-02-18 14:29:39] |
binaryduke - Posts: 369 |
Use the ranges for the column in question and set the color for the lowest range from 0 to your threshold to match your chart's background color.
[2024-02-18 20:44:53] |
Sierra_Chart Engineering - Posts: 17174 |
We will see about adding a setting for this.
