Date/Time: Mon, 25 Nov 2024 16:46:50 +0000
Text Tool not working
View Count: 229
[2024-02-16 19:33:08] |
User182629 - Posts: 4 |
I types notes on my charts and was doing so today. Somehow, I must have screwed up something because now the text tool is not working. I tried updating to the newest version hoping it would fix it but no luck. When I type text it appears on the top of the chart border, not on the chart.
[2024-02-16 19:49:15] |
John - SC Support - Posts: 36249 |
Please give us an image of what you are seeing. And are you getting the "Type Text" window that you actually type your text into when you click on the chart to place the text? Also, are you using the "Type Text" or the "Stationary Text" tool? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-16 20:08:00] |
Im not sure what happened with the text tool but the stationary text tool is working so that gives me what I need. Thanks |
