Date/Time: Mon, 25 Nov 2024 16:52:46 +0000
[Programming Help] - ACSIL Help with resetting variables on symbol change.
View Count: 221
[2024-02-16 19:27:58]
User92573 - Posts: 530
Dear Support Board
Can anyone provide some help with resetting variables on symbol change.
I have the following:
// Do Processing
SCString SYM = sc.Symbol.GetChars();
SCString str_CURRENT_SYM;
if(str_CURRENT_SYM != SYM)
  // clear values
..... etc. etc.
  // code blocks
// last line before closing bracket
str_CURRENT_SYM = SYM;
But clearly I've got it wrong.
Any help appreciated.
Many thanks
[2024-02-17 04:20:01]
User43 - Posts: 101
you need to make your str_CURRENT_SYM persistent in order to work as intended.
currently your str_CURRENT_SYM will be a newly initialized on each bar, rendering your
last line before closing bracket obsolete.
see
Persistent Variable Functions
[2024-02-17 16:27:20]
Thank you. Well I used int& and float& in the study for that very reason and completely forgot about the need for a PV with SCString.
Great help thank you!
[2024-02-17 16:34:35]
User43 - Posts: 101
Yeah, the non persistence of variables is a trap I get into myself often enough.
Glad I got you on the right track.
