Date/Time: Mon, 25 Nov 2024 16:30:00 +0000
How to black out a chart?
View Count: 277
[2024-02-16 19:13:02]
funbun - Posts: 90
I'm monitoring a few symbols using sets of charts.
I'd like to "black out" a chart when I'm no longer interested in following a certain symbol, reducing visual clutter.
What's the best method?
[2024-02-16 19:45:04]
John - SC Support - Posts: 36248
You can "Hide" the window, which is best from a resources standpoint, as that chart will use very little resources. Refer to the following:
Window, CB and CW Menus: Hide Window (Window)
If Hiding is not what you want, then to remove the bars for the chart select "Chart >> Graph Draw Types >> Blank". And you would need to "Hide" any studies on the chart. Refer to the following:
Chart Menu: Graph Draw Types (Chart menu)
Chart Studies: Settings and Inputs Tab >> Hide Study
[2024-02-17 03:40:23]
Sierra_Chart Engineering - Posts: 17174
Also refer to:
Disabling Sierra Chart User Interface to Eliminate Graphics Load
[2024-02-17 09:46:42]
User61168 - Posts: 403
I use control Button to do 1-click toggle between "Hide All Studies" and "unhide all studies". There are control buttons to switch between graph styles and bar types as well... super convenient!
