Date/Time: Mon, 25 Nov 2024 16:39:54 +0000
dom trading
View Count: 217
[2024-02-16 13:56:05] |
User161159 - Posts: 41 |
I am not seeing the order ladder chart. Please guide attached current display also can I see price movements and trade from that ? Is there any documentation on this ? Please share |
Private File |
[2024-02-16 18:38:48] |
John - SC Support - Posts: 36249 |
The image you gave us is of the "Trade Window". Select "File >> Find Symbol", select the symbol you want, and then select the button for "Open Trading DOM", or if you have a chart already open for that symbol, then select "File >> Open Trading DOM for Chart". Refer to the following: File Menu: Find Symbol (File) File Menu: Open Trading DOM for Chart (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
