Date/Time: Wed, 27 Nov 2024 04:33:38 +0000
How to Change size of Grid Dots
View Count: 985
[2014-08-05 02:57:49] |
User27189 - Posts: 26 |
Try as I may, I cannot find in the manual how to adjust the dot size of the horizontal grid. I can only get the huge, default polka-dot pattern glaring all over my charts. I would like a tiny, unobtrusive pin-dot grid on both my bar/candlestick charts as well as my TPO profile study charts. Thank you for your help.
[2014-08-05 04:43:09] |
You can change the "Chart Grid" Width through Global Settings >> Graphics Settings. Here is complete documentation: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html By default it was one pixel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-05 04:43:38
