Date/Time: Mon, 25 Nov 2024 16:39:54 +0000
Crosshair Issue
View Count: 242
[2024-02-15 17:16:26]
User329685 - Posts: 2
The crosshair value boxes for price and time are black and I cannot see price and time. I've tried to change the color in graphic settings but color isn't applying.
[2024-02-15 19:30:32]
John - SC Support - Posts: 36249
There is a new setting for this in the recent releases, so you need to change the color for the text in those boxes. Refer to the second bullet point at the following link:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2595
[2024-02-15 20:19:31]
Hi John,
Thank you for your response, however this did not fix the issue as the color change did not apply and I'm left with the same issue.
[2024-02-15 20:43:58]
Update to the latest release to make sure you are not viewing a separate issue that was on some previous releases. Then make sure the new setting is set as you need.
[2024-02-15 20:55:03]
Sierra_Chart Engineering - Posts: 17174
Make sure you are setting this through the right Graphics Settings window. There are two of them:
Graphics Settings: Introduction
