Date/Time: Mon, 25 Nov 2024 16:42:50 +0000
New SC user settings
View Count: 206
[2024-02-15 10:30:20] |
User585104 - Posts: 142 |
Hi, Someone I know has decided to join SC. How can I share just my control bar button setup with them? Thank you |
[2024-02-15 16:47:52] |
John - SC Support - Posts: 36249 |
The file is named "Sierra4.config" and is located in your main Sierra Chart installation folder (typically C:\SierraChart). This contains all of your settings, including the control bars and global graphics settings, etc. Just make sure they are aware that they may need to reset a few items. For information on the various files and what they do, refer to step #5 at the following link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-15 17:02:29] |
Thank you
