Date/Time: Mon, 25 Nov 2024 16:28:10 +0000
Market profile stuck
View Count: 176
[2024-02-14 23:00:28]
Christopher Stevens - Posts: 2
Hi, I have a chart book set up with separate Market profile and Day VWAP windows. I have had a break from the market replay (since before Christmas) but now the market profile is stuck on 02-01-2024 even though the VWAP is running on 05-01-2024. Both are on ES Mini ESH24-CME. It was functioning ok before. Now that I have come back to it, the market profile seems to be stuck. I have tried a software update which appears to have been successfull but the problem persists.
The price appears to be synced up ok and is moving normally but sometimes it stops altogether.
I haven't got any chart linking set up, market profile is #1 and VWAP is #7.
Can anyone help please?
Thank you
Chris
[2024-02-15 16:52:07]
John - SC Support - Posts: 36248
Duplicate the chart and then remove the TPO study from the duplicated chart. Make sure the underlying bars are properly updating. If not, then refer to the following:
