Date/Time: Mon, 25 Nov 2024 17:44:17 +0000
[User Discussion] - DOM to display both the recently traded at bid/ask highlighted at the same time
View Count: 212
[2024-02-14 21:15:07] |
User191029 - Posts: 6 |
Hello everyone, How does one get the DOM to display both the recently traded at bid/ask highlighted at the same time vs just the last traded either bid or ask? - I want both to show and be highlighted like the DOM on the last side - I am sure it is something simple, but I am running in loops through the documentation... |
DOM-SC.JPG / V - Attached On 2024-02-14 21:14:41 UTC - Size: 59.54 KB - 57 views Attachment Deleted. |
[2024-02-14 21:26:42] |
Answering my own question Select DOM (in focus) Chart > Graphic Settings (Chart) Enable these two options (in the attached screenshot) and set the colors update: + disable these two options (in enabled) in the second attached screenshot If there is a better way, pls update post Date Time Of Last Edit: 2024-02-14 21:46:22
image_2024-02-14_162549870.png / V - Attached On 2024-02-14 21:25:53 UTC - Size: 28.67 KB - 58 views image_2024-02-14_164614193.png / V - Attached On 2024-02-14 21:46:17 UTC - Size: 11.76 KB - 58 views |
