Date/Time: Mon, 25 Nov 2024 17:34:09 +0000
reduce the size of footprint numbers
View Count: 208
[2024-02-14 19:01:43] |
User488910 - Posts: 1 |
Hi, how do I reduce the size of the numbers in the candles sticks footprint so I can fit in more data on the chart?
[2024-02-14 19:01:47] |
John - SC Support - Posts: 36253 |
Refer to the following Input and the two below it: Numbers Bars: Font Size Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
