Date/Time: Mon, 25 Nov 2024 17:48:35 +0000
Large volume trade indicator
View Count: 240
[2024-02-14 18:35:27]
User290704 - Posts: 12
As I use a heatmap, I have included the "large volume trade indicator" as a study.
Depending on the session, europe or us, the parameters needs to be changed.
For this reason, I tried to put 2 times the "large volume trade indicator" with the objective of having different colors to make the difference between both.
When I do that, it seems like the chart keeps downloading but never finishes ...
Is there anyways to fix this ?
This would be a way to get closer from bookmap I think.
Thanks,
[2024-02-14 18:36:27]
John - SC Support - Posts: 36255
There are no issues with having two copies of the "Large Volume Trade Indicator" on a chart. Just make sure you set each up so you can properly see what you want.
Given that you are having some issue, please get us your Message Log by following these instructions:
