Date/Time: Mon, 25 Nov 2024 16:53:12 +0000
Numbers bars
View Count: 420
[2024-02-14 17:44:39]
Terz - Posts: 2
I am only my 3rd or 4th day of free trial of sierra charts, I am trying to put on numbers bar study on to analyze the order flow, when I load the study numbers on candles are in mess, they go on top of one another and they go to much on the side so they are not visible, whole study is in mess and I tried to change some things to make it readable but I couldn't do it, is that a bug or what do I need to do in order to make it normal, when I see other people's tutorials on internet it is completely normal in their case and yes I reinstalled software and still doesn't work.
imageScreenshot 2024-02-14 183102.png / V - Attached On 2024-02-14 17:41:46 UTC - Size: 31.3 KB - 62 views
[2024-02-14 21:48:49]
John - SC Support - Posts: 36249
What is the symbol for this chart?
Do you have any other studies on there? We are not sure where the arrows in the center are coming from.
Also refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
[2024-02-15 18:29:27]
Terz - Posts: 2
Thank you, I found everything I needed in link u sent me.
