Date/Time: Wed, 27 Nov 2024 04:50:33 +0000
ADR (average daily range) indicator
View Count: 1206
[2014-08-04 23:21:06] |
narcese - Posts: 58 |
Which one of your indicators would best be described as ADR, average daily range.
[2014-08-05 04:53:52] |
In the current version of Sierra Chart, there is the Average Daily Range study which is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s347 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
