Date/Time: Mon, 25 Nov 2024 18:05:57 +0000
[Programming Help] - fetch tickl data using api or on python
View Count: 168
[2024-02-14 15:12:29]
User188445 - Posts: 11
Hi
I want tick data that is displayed on SC to be pulled for historic data as well as live data using api or directly on python for analysis. I need it to push all the data that is shown on the screen including cummulative delta. I need the candles to be 100 ticks long (best if that can be customized too).
Eagerly waiting for your prompt response.
Thanks.
