Date/Time: Mon, 25 Nov 2024 17:57:30 +0000
Failed to open the file
View Count: 211
[2024-02-14 01:14:22] |
User241010 - Posts: 1 |
Hi, I've a MAC BOOK pro M2 and I'm running parallels desktop on it, I'm having issue downloading the software on the Mac, it says " failed to open the file, I've also attached a screen shot for reference. I'd really appreciate it if you'd be kind enough to respond at your earliest connivence. Thank you |
Attachment Deleted. Private File |
[2024-02-14 16:06:44] |
John - SC Support - Posts: 36255 |
We recommend using the Zip installer in this case. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
