Date/Time: Mon, 25 Nov 2024 17:30:15 +0000
CROSSOVER using bar open vs bar close
View Count: 191
[2024-02-14 00:42:13] |
User14953 - Posts: 236 |
If SpreadsheetFunction CROSSOVER(range1, range2) operates using prior bar close vs bar close, what is a good way to operate using bar open vs bar close?
[2024-02-14 16:04:55] |
John - SC Support - Posts: 36253 |
It does not specifically work on the Bar Close. It works on whatever is the range of data that is given. So if you want to use the Open for one of the items to test in the crossover then reference the Open as one of the ranges. Refer to the information for this function here; https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#CROSSOVER_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
