Date/Time: Wed, 27 Nov 2024 04:30:40 +0000
Evening Session High/Low Lines on Day Session only TPO Chart
View Count: 1288
[2014-08-04 21:54:44]
User68474 - Posts: 201
Is there any way to create high/low lines for the evening session (i.e. in ES, 6 p.m.EST-9:29:59 a.m. EST the next day) which would continue to extend to and through the width of the developing Day Session (i.e. Start time=9:30 a.m. EST) until the close (i.e. 4:14:59 p.m. EST), but EXcluding the Evening Session TPO's and the space that the Evening session TPO's would normally occupy in a split session version?
In a similar vein, is there any way to create a simple narrow, highlighted rectangle which would, instead, "represent" the evening session but not take up much space/width so that the juxtaposition of the Day Session only Proflies still remain visually sequential (i.e. not interrupted by Evening Session profiles). The idea is to be able to see the structural information that the Day Session TPO's provide, but disregarding the Evening Session structure save for the High and Low.
Date Time Of Last Edit: 2014-08-05 00:28:36
[2014-08-05 05:02:08]
1. We do not fully understand the first question.
Based upon what we do understand, we recommend using the High/Low for Time Period-Extended study:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s246
You may also want to refer to help topic 28 here:
Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html
2. Your other question is even more complicated to understand. We do understand it. Generally advanced questions like this are not within the scope of our support .
Date Time Of Last Edit: 2014-08-05 05:02:34
