Date/Time: Mon, 25 Nov 2024 17:28:45 +0000
big 7
View Count: 198
[2024-02-13 20:47:22]
User411320 - Posts: 289
is there a way to create an index of the big 7 companies in S&P 500? either candle chart or a line on a chart (similar to a moving average)?
[2024-02-14 15:54:18]
John - SC Support - Posts: 36253
The easiest way is to use the "Custom Calculated Symbols". Refer to the following:
Another option is to use the "Sum - Bar" multiple times to get what you want. Refer to the following:
Sum - Bar
