Date/Time: Mon, 25 Nov 2024 17:47:19 +0000
Two Separate Charts in the same workbook
View Count: 139
[2024-02-13 16:35:32] |
User978379 - Posts: 1 |
Hi, Is it possible to view two separate charts in the same workbook. For example a $Gold Chart on the top of the screen. A second chart for example XAUUSD a Gold cfd underneath. This is so I can make a visual comparison of the two charts at the same time. Thanks |
[2024-02-13 16:39:09] |
John - SC Support - Posts: 36255 |
Yes, you can "tile" the windows within the Sierra Chart application and set them up however you want. Refer to the options starting at the following: Window, CB and CW Menus: Cascade (Window) Also, you can detach charts from the main window and set them up on your desktop however you want. Refer to the following: Window, CB and CW Menus: Detach/Attach Window (Window) And finally, another option is to use the "Add Additional Symbol" study so you can view additional symbols on the same chart. Refer to the following: Add Additional Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
