Date/Time: Mon, 25 Nov 2024 17:48:29 +0000
[User Discussion] - Trade statistics
View Count: 150
[2024-02-13 15:53:52] |
User993067 - Posts: 156 |
1. Under TAL, statistics is it possible to add standard deviation to the available metrics? I would like to compare my swing trades and scalp trades for efficiency and risk mgmt. 2. Depending on volatility I use different TW Config files...which vary exit targets, stops and trails slightly. I may have 3 different TW config files in use each day. I would like to compare the efficiency of my scalp trading versus swing trading statistically in SC. Can the Note section be modified with a drop down box to include multiple TWConfig files? currently i can only view all trades or separate individually by the note section. Or is it possible using the current text label to combine all of my scalp TWC files with 1 label and swing TWC files with another label...not sure of the functionality. |
