Date/Time: Mon, 25 Nov 2024 18:02:42 +0000
Footprint chart support for Small Caps?
View Count: 168
[2024-02-12 22:44:06]
richmondthefish - Posts: 1
Has anyone used Sierra Footprint charts for NASDAQ Small Caps or know if you can get data to feed 1 min time frames?
Right now I am using a trial version of ATAS but they have no historical data for them and even the real time seems to not work using dxfeed.
Can someone confirm if the footprint charting for Sierra works in real time for 1 min footprint time frames; Example would be BMR and MGIH from today? Also if it does what data feed are you using?
[2024-02-13 16:53:13]
John - SC Support - Posts: 36257
We can tell you that we have this data and there is no issue with it. We have about 1 year of tick data for U.S. Equities with data going back to around 2008 in 1 minute increments prior to the 1 year of tick data.
Attached is an image of BMR set for 1 minute bars. This is from our U.S. Equities Consolidated Tape exchange.
imageBMR[M] 1 Min #5 2024-02-13 10_50_57.196.png / V - Attached On 2024-02-13 16:53:08 UTC - Size: 37.95 KB - 52 views
