Date/Time: Mon, 16 Sep 2024 20:13:34 +0000
Limit Order book
View Count: 319
[2024-02-12 18:49:22] |
User411320 - Posts: 283 |
I have " Draw DOM graph on chart enabled", but i was wondering how I can have the actual numerical orders displayed on the chart instead of just lines
[2024-02-12 21:08:55] |
John - SC Support - Posts: 34457 |
[This post has been updated] You can view the numbers for the DOM Graph by enabling the option for "Chart >> Chart Settings >> Market Depth >> Show Volume Numbers" under the DOM Graph section. Refer to the following: Chart Settings: Show Volume Numbers (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-13 17:56:48
[2024-02-13 02:41:04] |
jmftattoo - Posts: 88 |
Best you can do is have the volume on those levels by enabling "Show Volume Numbers" in Chart settings>Market depth settings. Gets you something at least, but not as in depth as the actual dom. see image. - https://www.sierrachart.com/image.php?Image=1707792048383.png |
[2024-02-13 16:21:54] |
thanks both for your help
