Date/Time: Mon, 25 Nov 2024 17:48:13 +0000
Keep VbP Pinned to edge
View Count: 183
[2024-02-12 14:40:59] |
cesium - Posts: 85 |
Hello Support team, Im curious if there is a way to keep the VbP study pinned to the right edge when using the setting Multiple Profiles from Start Time to End Time under the Volume Graph Period Type setting. The reasoning being, to have the VbP study reset exactly at the turn of 0930 est without the view of a renko chart being obstructed in the early parts of the RTH session. I was previously using From start date-time to end date-time, and the issue i found was during ETH session, the VbP was being drawn and redrawn every few seconds. Ive read the documentation but cant locate which setting ive applied wrong thats causing this behavior. Its problamatic mainly because i have alerts set on this study, so they trigger outside of desired expectation during ETH. Thank you team Date Time Of Last Edit: 2024-02-12 14:41:41
[2024-02-12 20:15:44] |
John - SC Support - Posts: 36255 |
Refer to the following Input: Volume By Price Study: Always Display Last Profile Within View For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
