Date/Time: Mon, 16 Sep 2024 19:08:48 +0000
Laggy Second Instance
View Count: 155
[2024-02-12 14:35:02] |
connordw - Posts: 41 |
I run two instances. I have not had any problems with the second instance in the past. All of the sudden it has been extremely laggy and often gives me the "Not Responding" message. I have not done anything different to it and I've made sure I have the current version downloaded. Any ideas what might be wrong? Thank you.
[2024-02-12 15:50:06] |
Sierra_Chart Engineering - Posts: 16387 |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-12 16:00:14] |
It seems to be working now. I guess it was just taking a while to get things loaded, even though it seemed like everything was already loaded and I wasn't getting any messages about data still loading.
