Date/Time: Wed, 27 Nov 2024 04:32:57 +0000
sc.DailyHigh / sc.DailyLow related questions
View Count: 954
[2014-08-04 16:02:13] |
ejtrader - Posts: 688 |
SC Team - Have couple of questions related to sc.DailyHigh & sc.DailyLow values( instrument in question ES). Based on my observation - It appears like these values are independent of the session settings at the chart level. Do you get this information from CME? If not - are you calculating this on the fly? Trying to find a reliable way to use these values historically on intraday basis and trying to understand - what session settings needs to be used for this ( so I can calculate this using high/low for time period ). Though can overlay the information from Daily Chart - it doesn't give intraday data for prior days and trying to see if there is any specific session setting that can be used in combination with high/low timeperiod to match up these values. Thanks Date Time Of Last Edit: 2014-08-04 16:16:19
[2014-08-04 19:06:34] |
Refer to the documentation for these ACSIL members here: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scDailyHigh Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
