Date/Time: Mon, 25 Nov 2024 17:43:39 +0000
Topstep Rithmic from Asia
View Count: 428
[2024-02-12 12:48:32] |
User953554 - Posts: 9 |
Hi and I am currently in Indonesia and Trading a Topstep combine using the Server settings: Rithmic Direct - DTC with Topstep-Chicago Area-Non-Aggrigated and wanted to ask if I should choose different settings like 'TopstepTrader-Singapore-Non-Aggrigated' from the Server(List) as It's the closest to my location? Also when I am home in the UK should I bee using the Europe (or Frankfurt) Server. Or Do I just set and leave it on the Topstep-Chicago Area-Non-Aggrigated as that's where the CME is based? I have Service Package 12 I don't have connection issues my current settings but sometimes I have a slight delay closing positions (but nothing to worry about) but wondered if I was hindering execution speed by having less than ideal settings Thanks in advance Andy |
[2024-02-12 15:46:08] |
Sierra_Chart Engineering - Posts: 17174 |
This is not within the scope of our support. You need to ask Rithmic.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-12 15:46:13
[2024-02-13 18:08:34] |
ok can you tell me if using the Rithmic Direct - DTC is correct? |
[2024-02-13 22:50:25] |
John - SC Support - Posts: 36253 |
Yes, "Rithmic Direct - DTC" is the correct service to select when you are wanting to connect with TopStep.
