Date/Time: Mon, 25 Nov 2024 18:30:37 +0000
Displaying issue when switch between chartbook.
View Count: 221
[2024-02-12 05:18:51]
livetotrade - Posts: 17
When i switch between chartbook the chart from other chartbook show up on my current chartbook.
https://www.sierrachart.com/image.php?Image=1707714685386.png
As you can see on above image, NQH24_FUT_CME is not belong to NADRO_ES but it's always there when i switch between them.
Similarly to this one https://www.sierrachart.com/image.php?Image=1707714814765.png when i switch to NADRO_RTY the ESH24_FUT_CME chart is there on the right (this one belong to NADRO_ES chart book).
Please help. THanks
[2024-02-12 08:57:17]
Sierra_Chart Engineering - Posts: 17174
Go to each chart and then make sure this command on the Window menu is unchecked for it:
Window, CB and CW Menus: Window Always Visible (Window)
[2024-02-12 14:40:15]
Thank you it's fixed.
