Date/Time: Tue, 22 Apr 2025 10:14:29 +0000
Average Daily Volume
View Count: 622
[2024-02-11 19:33:57]
User110225 - Posts: 23
Hello.
Thanks in advance for your help.
I would like to find the average daily volume for the sp500.
When I look under Windows > Chart Value Window, I can see the volume for the day, unfortunately this isn't the average volume, its the total volume for the day.
I was wondering if there is a way to see the average volume for the day.
I have tried searching for this but I haven't had any success.
I look forward to hearing back from you.
Best wishes
Chris
[2024-02-11 20:36:36]
User43 - Posts: 102
You can just add the volume study to your chart and then a moving average study based on the volume study.
[2024-02-13 23:26:40]
Sierra_Chart Engineering - Posts: 19305
Refer to:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
[2025-01-23 19:49:04]
User270494 - Posts: 2
How do I install the daily volume on a chart
[2025-01-23 22:33:59]
John - SC Support - Posts: 39395
You would need to start with a Daily chart and then add the Volume study. Refer to the following:
Chart Settings: Days-Minutes-Seconds-Milliseconds Per Bar (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu)
Volume
