Date/Time: Mon, 25 Nov 2024 18:31:01 +0000
Volume at Price Threshold Alert V2 Price Overlay used in Alert Formula
View Count: 201
[2024-02-11 11:45:13] |
User486817 - Posts: 83 |
Hello, I have a main chart with the study/price overaly study on it. The study/price overaly references the Volume at Price Threshold Alert V2 from another chart. The SG I would like to reference in a formula is ID31.SG1 (Trigger 0). my question is, how can i reference Trigger 0 (SG1) from this price overaly study in an alert formula? i tried the following: = AND(alert condition 1, alert condition n, ID31.SG1[-1]<>0) -- this approach did not work properly for some reason. i'm trying to filter the alert to whether or not trigger 0 is present anywhere in the previous bar or not. the output of trigger 0 if present seems to be price, so i put SG1<>0 in the formula -- if this approach is incorrect, please advise on how i can place this in my alert formula. Kindest Regards, |
[2024-02-12 17:35:35] |
John - SC Support - Posts: 36261 |
If the Study/Price Overlay is setup properly, then what you are doing is correct. Note that you do not need to put "<> 0" as just having the subgraph by itself evaluates it as a boolean, so any 0 value is false and non-zero values are true. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
