Date/Time: Wed, 27 Nov 2024 04:54:50 +0000
Profit and Loss in points only ?
View Count: 1889
[2014-08-04 15:19:35] |
User021827 - Posts: 174 |
When attaching a trade window to a chart , is it possible to display profit and loss in ticks or dollar amount in the P&L and Net P&L section ? Or is points the only way to display profit and loss ? regards |
[2014-08-04 18:10:44] |
I would like to change the format the way you can change it in the trade activity log. You can select ticks, currency, points,....... in the activity log. Can you set the trade window like that ? regards |
[2014-08-04 18:43:34] |
Yes, this can be done. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-04 19:05:40] |
hi Yes thank you very much ! regards |
