Date/Time: Mon, 25 Nov 2024 18:49:48 +0000
Chart fixed time frame
View Count: 232
[2024-02-11 09:58:55]
Pedro7 - Posts: 22
Is it possible to show on a chart only eg the last hour ?
So if i put up 1 minute candles i see the last 60 candles, if 15 minute candles i see the last 4 candles, if i select tick charts the chart automatically adapts to the last 60 minutes.
[2024-02-12 16:21:31]
John - SC Support - Posts: 36264
There is not a way to only load a single hour. You can only control it down to a single day.
But, you can always adjust the display to only show you what you want by expanding/contracting the Bar Spacing.
