Date/Time: Sun, 24 Nov 2024 20:56:22 +0000
[Programming Help] - GDI Brush not working properly
View Count: 372
[2024-02-10 22:57:18]
User339987 - Posts: 13
Dear Support,
When trying to compile my ACSIL programs on newer version ( for example 2599 ), I am experiencing issues with Brush color not been set correctly. It seems the color is stuck on the whatever color been set first. It's even affect different studies.
Attached two files for example, if you change the study order, you can see the color change for both studies at the same time.
Thank you very much.
attachmentGDIExampleKC.cpp - Attached On 2024-02-10 22:50:50 UTC - Size: 3.04 KB - 194 views
attachmentGDIExampleKC_b.cpp - Attached On 2024-02-10 22:50:56 UTC - Size: 3.05 KB - 297 views
[2024-04-26 11:49:17]
BTW, it appears that if OpenGL for Graphics is enable, things seem to work properly.
[2024-04-26 15:37:39]
gcUserStudies - Posts: 106
May be related to what I posted here:
Discrepancies in GDI Drawings Output with OpenGL Enabled/Disabled in Sierra Chart
