Date/Time: Fri, 02 Oct 2026 18:48:19 +0000
Generation of Alerts on disabled studies?
View Count: 558
[2024-02-10 21:17:41]
User61168 - Posts: 489
Reporting a possible bug. For studies that are disabled (such as Trading system based on Alert Condition) with Enabled=checked under the Alert Tab, the alert should not be generated if the entire study is disabled.
Just for your awareness as it is not a high priority issue (more of a performance drag as I do like to have disabled studies in my collection for rapid access during development). I am on v2568
[2024-02-10 21:22:36]
Sierra_Chart Engineering - Posts: 25028
Studies cannot be disabled. The Disable option you are referring to does not disable alerts. This will not change.
There is a 0% chance of any change like this.
