Date/Time: Mon, 16 Sep 2024 19:30:50 +0000
[User Discussion] - Log Scale Padding Broken
View Count: 154
[2024-02-10 05:33:57] |
esMike - Posts: 69 |
Hello, would it be possible for you to fix padding for Log Scale charts? Percentage padding doesnt add any space to the top or bottom. Maybe use fixed top/bottom padding for log scale if it's an issue? |
[2024-02-10 05:46:12] |
I was able to fix it for myself by making this chart spacer study, but you should still fix log scale padding. int barsOnChart = sc.IndexOfLastVisibleBar - sc.IndexOfFirstVisibleBar;
sc.Highest(trueHigh, highestBar, barsOnChart); sc.Lowest(trueLow, lowestBar, barsOnChart); float chartRange = highestBar[sc.Index] - lowestBar[sc.Index]; //Spacer if (trueMedian[sc.Index] > trueMedian[sc.Index - 1]) { hiddenChartSpacer[sc.Index] = trueHigh[sc.Index] + chartRange * 0.02f; } else if (trueMedian[sc.Index] < trueMedian[sc.Index - 1]) { hiddenChartSpacer[sc.Index] = trueLow[sc.Index] - chartRange * 0.02f; } |
[2024-02-10 21:23:29] |
Sierra_Chart Engineering - Posts: 16387 |
Yes definitely develop your own solution. There is not anything broken. This is by design: would it be possible for you to fix padding for Log Scale charts?
