Date/Time: Mon, 25 Nov 2024 17:56:09 +0000
Drawings not copied on other charts
View Count: 339
[2024-02-09 19:25:15] |
User213504 - Posts: 69 |
I have a daily chart with support levels drawn with horizontal lines. I have this chart referenced on 5 other charts but the lines are not seen on them. These charts all have drawing from other charts so that is working on them. It is only from the daily chart that it's not working. I really don't want to remove this chart because it would be horrendous redoing all the levels. I'm using version 49132. Ron |
[2024-02-09 20:58:24] |
John - SC Support - Posts: 36255 |
Is the daily chart the same symbol? If not, then you would have to enable the option for "Show Chart Drawings from Different Symbols". Refer to the following: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) The other thing to check is on is that the levels on the Daily chart may be at a very different price from the range of prices that you are viewing on your intraday chart. So check the price levels of the drawings and check if the drawings are really there, but at a level that is not in view. If not the above, then refer to the other possibilities at the following link: Chart Settings: What to Do If Chart Drawings Do Not Copy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-12 14:37:50] |
Fixed. Thank you.
[2024-02-13 20:06:37] |
It was fixed for 1 day. I created another daily chart and the drawings do copy to other charts from it so I'm going to have to transfer the levels to the new chart.
