Date/Time: Mon, 25 Nov 2024 17:34:46 +0000
changed broker from Infinity to Clear Edge
View Count: 351
[2024-02-09 15:45:28]
User161159 - Posts: 41
I have made payment to Sierra charts so should be good there.
I have changed brokers but I am still getting delayed data
I am struggling to get my charts going
please help
Sam
[2024-02-09 16:03:19]
John - SC Support - Posts: 36253
You have not made a connection to your new brokerage account. Your "Verified Until" date is currently showing as "2023-12-31".
If you were setup with Edge Clear to use the Teton Order Routing Service, then follow the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2024-02-09 16:48:23]
how do I connect to ne brokerage account?
[2024-02-09 16:48:36]
new
[2024-02-09 18:05:24]
Follow the instructions at the following link starting at Step #6:
[2024-02-10 02:04:23]
on Sierra charts I am getting the link to "connect to data feed" disabled.
My broker at Clear Edge says I need to sign agreements and make right selections in Sierra charts.
I am getting bounced between Clear edge and Support here. All this time, my issue persists.
please help.
[2024-02-10 03:02:50]
Sierra_Chart Engineering - Posts: 17174
At this time, everything you need with your account is activated and you have successfully connected to Teton.
So the next step is for us to look at a particular issue with an individual symbol.
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-02-12 15:00:40]
thank you for guiding.
I am getting live feed now.
I do have 2 issues I need your help with
1. what is symbol for micro emini ?
2. how do I trade
a) live
b) sim
Sam
[2024-02-12 20:20:31]
1. The symbols are different depending on what service you are set to. It is always best to use the "File >> Find Symbol" to get the correct symbol for your service. Refer to the following:
File Menu: Find Symbol (File)
For the Micro E-Mini when you are connected to the Teton Order Routing Service, the symbol would be MESH24_FUT_CME
2. To trade live, make sure you have your connection to your trading service setup properly in your Data/Trade Service Settings, and then make sure the option for "Trade >> Trade Simulation Mode On" does NOT have a checkmark next to it (this means you are in live trading mode).
To trade in Simulation mode, it's the opposite of the above. Make sure the option for "Trade >> Trade Simulation Mode" HAS a checkmark next to it.
Trade Simulation: Using Trade Simulation
