Date/Time: Mon, 25 Nov 2024 19:47:48 +0000
Detached charts windows to be tiled and arranged as a single window tab
View Count: 217
[2024-02-09 14:27:13] |
fried4104 - Posts: 66 |
Hey, Is there a possibility to have (in the future) all detached charts in the secondary monitors behave as a single window/tab? (i.e. similar to the main app window, but without the menus etc?) Like to keep the current appearance, but unify them within a window. It's really difficult to remember and keep the order in check, since they move around depending on which you re-attached/detached last. It would be awesome if something like this could be achieved. Many thanks for the flexibility of an amazing software! |
[2024-02-09 15:45:38] |
John - SC Support - Posts: 36277 |
As we understand what you are asking for, you can do this now by using a Sub-Instance. This will give you a full Sierra Chart instance separate from the Main instance in which you can have your charts attached to that window. Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-09 18:02:10] |
Hey John, Yes, I know about using sub-instances or even secondary or third sierra installs in parallel with the main one. I was reffering of keeping all charts within the same instance and unify the detached charts in a single window. To avoid minimize/maximize individual charts, rather have them grouped within the same window. I attach the secondary monitor detached charts. Currently each chart is an independed window. I would like similar appearance but having the ability to add/resize and group them within a single window. Date Time Of Last Edit: 2024-02-09 18:03:34
unify this.png / V - Attached On 2024-02-09 18:01:15 UTC - Size: 6.42 KB - 55 views |
