Date/Time: Wed, 27 Nov 2024 04:35:35 +0000
another pair of questions
View Count: 923
[2014-08-04 12:48:39] |
User30743 - Posts: 365 |
hi, i got two questions for u 1) i use two chartbooks for my trading (viz picture 1) and i dont know how to switch between them when i hide the upper line (unclicked show chartbook tabs in global settings). is there any way to define a keyboard shortcut? or any other way ? (viz picture 2) 2) i use 4 charts with the same timeframe and the same study (coundown timer) and it shows me different time.. how is it possible? viz http://www.sierrachart.com/image.php?l=1407156400715.png |
picture 1.png / V - Attached On 2014-08-04 12:48:31 UTC - Size: 110.09 KB - 364 views picture 2.png / V - Attached On 2014-08-04 12:48:36 UTC - Size: 114.95 KB - 354 views |
[2014-08-04 16:53:12] |
1. Use the "CB" menu at the top of Sierra Chart. 2. This is the result of how you have the Session Times set to: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
