Date/Time: Mon, 25 Nov 2024 19:21:35 +0000
Odd problem with left alignment on volume profiles.
View Count: 220
[2024-02-09 08:17:39] |
User666015 - Posts: 49 |
Hi, I have a strange problem with a new chart I am building, I have the value area and outline text aligned left and this works fine unless the line comes up to present time - then the text is no longer left and moves to the right side values scale, this may be a little bug? Here's a screenshot where you can see the aligned left text in the right scale: https://www.sierrachart.com/image.php?Image=1707466383832.png I have also attached a screenshot of the settings... Thanks, Bill |
Attachment Deleted. Private File |
[2024-02-09 15:24:22] |
John - SC Support - Posts: 36275 |
It's not a bug, it's specifically the way it is programmed. The current day labels are displayed in the Values Scale regardless of the setting.
