Date/Time: Mon, 25 Nov 2024 08:30:34 +0000
Trading DOM Studies bug
View Count: 299
[2024-02-09 04:37:01] |
User652903 - Posts: 25 |
SUMMARY: P/L Text is overwritten by background on Trading DOM, rendering P/L invisible. Open a Trading DOM: 1) open a study that will color the background using the Draw Styles "Fill Top" and "Fill Bottom"; you can use Volume Value Area Lines or you can Overlay any outside study; the result is the same; 2) open the study Trading: Profit/Loss Text; No matter what order you put the studies in, or what study settings you use (including "Draw Study Underneath Main Price Graph"), the colored background will always overwrite the P/L text, hiding it from view. It is impossible to put the P/L text on top of the background. This behavior does not happen on regular charts; only on the Trading DOM. The screen shot shows the before and after of scrolling up; you can see the purple background covers the P/L. I have wrestled with this for several days; no combination of settings produces the correct behavior. SC: please add an option to the P/L Text study for "Draw Above Main Price Graph", like is available on the Clock study. Both the Clock and P/L should be on top of everything else. Date Time Of Last Edit: 2024-02-09 07:29:53
Screenshot 2024-02-08 at 11.35.11 PM.png / V - Attached On 2024-02-09 04:35:58 UTC - Size: 168.87 KB - 78 views |
[2024-02-09 15:10:24] |
Sierra_Chart Engineering - Posts: 17172 |
We will look into this: SC: please add an option to the P/L Text study for "Draw Above Main Price Graph"
[2024-02-10 04:03:16] |
Thanks guys
[2024-02-28 07:48:35] |
Just pointing out that this bug was not fixed in Version 2604. It shouldn't be much heavy lifting. Please implement.
