Date/Time: Mon, 25 Nov 2024 19:52:16 +0000
Maintain same color for TPO periods when merging profiles
View Count: 165
[2024-02-09 03:44:36]
joshtrader - Posts: 488
If I have two profiles which use letters A - M (13 periods) and merge them, the first A in the merged profile will use color 1, and the second A will use color 14. Is it possible for both A's to use color 1? I know I can define color 14 to be the same as 1, but this becomes an issue as there are only 18 colors definable in the settings.
[2024-02-09 15:10:53]
John - SC Support - Posts: 36277
The only way to have this work would be to define only 18 letters for your Letter Sequence. Then each letter will use the same color.
