Date/Time: Thu, 31 Oct 2024 10:12:42 +0000
Wide range bar study showing only one color
View Count: 188
[2024-02-08 22:19:36] |
OliviaKim - Posts: 6 |
Hi, When I add wide range bar study, it prints only up color for up candle, AND down candle as well. As a result, wide range bars down side look like exactly up bars. There is no single down bar prints at all. Is there any way to fix this? My global graphics set has color bar into 2 colors normal. I didn't force it into one color, if this is some required info for you. Thank you! Olivia |
[2024-02-08 23:59:18] |
John - SC Support - Posts: 35639 |
There are 3 schemes for the Wide Range Bar study. Only Scheme 2 (x Bar WR) has 2 coloring options. Refer to the information here: Wide Range Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-20 01:30:16] |
I see. x Bar setting works good for me! Thank you so much for the tip. BTW, I love Sierra chart. It took a while to learn it, but I loooooove its replay and the versatility to deploy what I want on charts! |
