Date/Time: Mon, 25 Nov 2024 19:38:43 +0000
QuoteSpreadsheet
View Count: 150
[2024-02-08 21:38:29] |
User841161 - Posts: 221 |
Is there a way to get current date on a field(column) in the QuoteSpreadsheet?
VXQuoteSpreadsheet2-8-24.PNG / V - Attached On 2024-02-08 21:38:16 UTC - Size: 84.4 KB - 55 views |
[2024-02-08 23:47:27] |
John - SC Support - Posts: 36277 |
The Quote Spreadsheet is largely a standard Sierra Chart spreadsheet, particularly outside of the main columns (i.e. column S in your example). So enter the following formula to get today's date: =TODAY() Then highlight the cell and select "Spreadsheet >> Number Format" and set it to "Date". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
