Date/Time: Mon, 25 Nov 2024 08:33:59 +0000
Label Column only
View Count: 298
[2024-02-08 17:47:23]
User547290 - Posts: 58
Is there a way when you turn on a chart DOM to have only the Label Column on and not have the B/S. Would be nice to be able to save space on chart you are not trading on.
[2024-02-08 18:06:57]
Yes, you can do this by turning off the option for "Trade >> Trading Chart DOM On" and turning on the option for "Trade >> Show Market Data Columns".
Then in the "Customize Chart/Trade DOM Columns" remove the Bid/Ask Size columns (you will have the Buy/Sell Orders columns, but these will not actually show anything). Then add the Label (or other columns as you want).
[2024-03-14 02:27:00]
That is what I was trying to remove. I would like just the price and the label column and not have the buy and sell column. Screen space is a premium and every 1/2 inch counts.
[2024-03-14 15:02:49]
Follow the steps we outlined above. When you do so, the Buy/Sell columns will be very small. This is the best option available.
