Date/Time: Mon, 25 Nov 2024 19:26:20 +0000
Should Install Every Time I open the Platform
View Count: 180
[2024-02-08 15:44:29]
User140175 - Posts: 3
Every time I open the platform, it says that my version is too old, and I should download the installer. I follow these steps: I download version 11, install it, open the platform, but if I close it and open it again, it still shows the same message prompting me to download and install. What should I do?
imageupdates.png / V - Attached On 2024-02-08 15:42:25 UTC - Size: 340.52 KB - 62 views
imagesierra 2.png / V - Attached On 2024-02-08 15:42:33 UTC - Size: 65.81 KB - 54 views
[2024-02-08 15:54:47]
User43 - Posts: 101
How do you open Sierra Chart?
Try going to your installation folder
"D:\projecte\TRADING\apex\"
Find the "SierraChart_64.exe" there and start it.
If that does solve your issue, the short cut you use so far points to a different location, and should be updated.
[2024-02-08 16:14:52]
Sierra_Chart Engineering - Posts: 17174
You have multiple installations of Sierra Chart on your system. Make sure you are starting the correct one. It is in this folder:
D:\proiecte\TRADING\apex\
As has been said run the SierraChart_64.exe file there.
[2024-02-09 06:13:35]
Problem solved. Thank you so much for your answer!
