Date/Time: Mon, 25 Nov 2024 19:23:47 +0000
Chart Drawing Properties window doesn't pop on demand
View Count: 186
[2024-02-07 22:20:08] |
funbun - Posts: 90 |
When I right click on a line and click "Chart Drawing Properties" the window doesn't show. Version 2592. I exported the platform's settings to another computer it does the same thing. Is there a certain setting that might cause that behavior? I can't config my drawing tools. |
[2024-02-07 23:15:14] |
John - SC Support - Posts: 36275 |
This was an error in a couple of releases around the one you updated to (2592). Please update to the latest release which has this fixed by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
