Date/Time: Mon, 25 Nov 2024 19:36:08 +0000
Still No DAta for YMH-CME
View Count: 229
[2024-02-07 19:17:59]
User360283 - Posts: 504
YMH24-CME No data for moths Insanity
I have done everything you requested !
Suggest you sign in to my PC and get it fixed
Please
[2024-02-07 23:03:32]
John - SC Support - Posts: 36277
As noted in another post, if your "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" is set to "SC Data - All Services" then the correct symbol is "YMH24-CBOT" (note it is -CBOT, not -CME).
But in the end, the best thing to do is to use the "File >> Find Symbol" window to find the symbol you want, which will then have it in the correct format for the service you have selected.
[2024-02-09 16:52:53]
thanks
[2024-02-09 18:05:49]
Are you good now?
