Date/Time: Mon, 25 Nov 2024 19:54:53 +0000
How to put label in Volume By Profile POC
View Count: 276
[2024-02-07 11:15:09]
User285179 - Posts: 14
How can I write label with POC value in volume by price?
imagepoc.png / V - Attached On 2024-02-07 11:14:48 UTC - Size: 78.25 KB - 67 views
[2024-02-07 16:50:10]
John - SC Support - Posts: 36277
We are not sure what exactly you are trying to do. Can you please give us additional information.
[2024-02-07 22:31:24]
Did you see the attachment? As you can see, POC is 926 (got from volume by price study), can i write any custom text with 926? Like (LEVELPOC: 926)
[2024-02-07 23:20:04]
We assume you got the 926 to show up using the "Value Label" in the subgraphs. There is also the "Name Label" that you can use, and by setting a "Short Name" for the subgraph, you can have whatever text you want in that label. Refer to the following:
Chart Studies: Subgraphs Tab >> Name and Value Labels
Chart Studies: Subgraphs Tab >> Short Name
But there is not a way to use the "Value Label" and add text to it.
If you want to be able to place text wherever you want and have it update its position, then you would need to create a custom study. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
